Inside table
Mwamba
Mwamba Member Posts: 22
How do you get the table in the upright position??   We have tried just about everything!!  It shouldn't be this hard :-)
  • greggill
    greggill Member Posts: 45
    I've struggled with both putting it up and taking it down. Once you figure it out you'll have it. Pull forward and up. I doesn't pull straight up.
  • 2Cougs
    2Cougs Member Posts: 935
    I agree... Once you figure it out it becomes easy.  If your table is like mine, I put one foot on one of the table feet and do just like greggill says... Sort of toward and up or away and up (depending which direction the table was put in ), but not straight up.
  • ericnliz
    ericnliz Member Posts: 4,437
    Ha, Mine went out & about! ;)
  • Mwamba
    Thanks all, I'm going to try it now.   If it's going to be a hassle, soon ours will follow suit with ericnliz's :-)
    That was your problem, ericnliz--yer supposed to pull the table up and around, not out and about!  :-)
  • ericnliz
    Good one @ScottG! After giving that table numerous DNA samples, OUT-SKIE!
  • Mwamba
    edited July 2017
    Mission accomplished!   Pulled it forward and up with my foot on the base but had to do it on both sides.   Maybe the previous owners didn't bother with it much and it just has to be loosened up a bit ;-)    Thanks again all!
