Inside table
Mwamba
Member Posts: 22
How do you get the table in the upright position?? We have tried just about everything!! It shouldn't be this hard :-)
I've struggled with both putting it up and taking it down. Once you figure it out you'll have it. Pull forward and up. I doesn't pull straight up.
I agree... Once you figure it out it becomes easy. If your table is like mine, I put one foot on one of the table feet and do just like greggill says... Sort of toward and up or away and up (depending which direction the table was put in ), but not straight up.2016 T@B CS-S silver with white trim and WSU themed
Ha, Mine went out & about!
Eric aka: Lone Wolf -
Thanks all, I'm going to try it now. If it's going to be a hassle, soon ours will follow suit with ericnliz's :-)
That was your problem, ericnliz--yer supposed to pull the table up and around, not out and about! :-)ericnliz said:Ha, Mine went out & about!
Good one @ScottG! After giving that table numerous DNA samples, OUT-SKIE!2016 T@B MAX S-aka: WolfT@B
Mission accomplished! Pulled it forward and up with my foot on the base but had to do it on both sides. Maybe the previous owners didn't bother with it much and it just has to be loosened up a bit ;-) Thanks again all!
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
