New T@B owner and so excited! Picked up a 2015 CS. Curious about a few things and wanted to see what kind of answers I could find -
The battery has been dying after about 5 days when it storage. Ive turned on the lights and fan a few times to check it out but not much use at all. Unplugged the TV's and the radio to try and cut back on un needed power draws while not in use. I am thinking of disconnecting the fridge because we won't use it, is that a good idea? wondering if anyone has done that and / or if there's anything I should be careful of?
Any recommendations on what solar panels to get? I see that Zamp is the main brand they recommend but wondering if anyone has any luck with an alternate brand at a cheaper price? Or is Zamp the best way to go.
Thank you,
Chris
0 ·
https://www.google.com/search?q=renogy+panel+site:tab-rv.vanillaforums.com&ie=utf-8&oe=utf-8
And here is a generic search of the forums for "solar panel."
https://www.google.com/search?q=solar+panel+site:tab-rv.vanillaforums.com&ie=utf-8&oe=utf-8
I really wish my 2016 came with a battery disconnect switch to make it easier.
If plugging in, 15A is fine if not under heavy use.
Battery disconnects did not come standard until after 2015. Most of us with older trailers installed our own after quickly becoming convinced of their necessity!
