Hello, all.
We have a 2017 T@b Max S. It seems that the "hot" water coming from the Alde is more on the lukewarm side -- about 102 to 109 degrees and it is only good for about 2 gallons. We've tried moving the mixing knob to the maximum position, but that does not seem to help. Are we asking to much of the system? Is this as hot as the water gets? Any way to get hotter water?
Thanks
0 ·
Little Hot Water
It is an easy adjustment, just do a little at a time until you are satisfied with the temp!
While it could be a problem with your Alde's internal thermostat, more likely you need to adjust or replace your mixing valve.
We will give it a try tonight.
Thanks to all who responded!
