In addition to the stove in the T@B, we carry a two-burner propane camp stove for use outside. The stove has two shortcomings: 1) we rarely need two burners; and 2) the individual burners are too small to properly heat a cast iron fry pan or a small paella pan. I'd like to swap the current stove for a larger capacity (but still compact) single burner model, but my preliminary searches haven't revealed the right item. Any suggestions?
We are also considering moving some of the outdoor cooking tasks to the grill (Weber Q). Does anyone have experience with the griddle, roasting rack, or roasting shield made specifically for the Q?
Thanks in advance for any insight you camp chefs can offer!
2 ·
I actually returned this model because it was too large:
https://www.amazon.com/Coleman-2000020931-Powerpack-Propane-Stove/dp/B0009PUS6M/ref=sr_1_5/158-9639173-8145807?s=outdoor-recreation&ie=UTF8&qid=1487184789&sr=1-5&keywords=coleman+propane+stove
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
A note to those with older Q's that have a one-piece grate... The griddle is designed to replace half of the grate. Using it on top of the grate prevents the lid from closing properly, and may increase the time it takes for the griddle to heat up. You will need to purchase the newer two-piece grate (more than doubling the cost of the project), or be prepared to cut and modify your existing grate so that one half can be removed.
https://www.walmart.com/ip/Can-Cooker-Multi-Fuel-Burner-Camp-Stove/42426073?wmlspartner=wlpa&selectedSellerId=8540&adid=22222222227030275016&wl0=&wl1=g&wl2=t&wl3=61020253511&wl4=pla-109552690871&wl5=9019265&wl6=&wl7=&wl8=&wl9=pla&wl10=115787242&wl11=online&wl12=42426073&wl13=&veh=sem
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
Do you know what the BTU output is when using propane?
