Hi, I just set up, and thankfully I have shore power, BUT, I discovered I don't have any 12 volt power coming in from the battery.  I don't need it for this trip, but if I can't fix it I've got to plan ahead to drop the camper off for service on my way home.  I've checked the connections, and the fuse on the battery, I checked the circuit breakers, I checked the 20,30,40 amp fuses in the breaker box.  What else can I check?  My dad is coming to meet me to see if he can fix it, but I know the forum is the best place for advice.  If the inverter/converter was bad, that would affect my 110 power and not the 12 volt right?  Are there any tips on what to try to at least try to isolate the problem.  I still need to check the 10 amp fuses.  Any help is greatly appreciated. I will check back in a couple of hours.
                0 ·
J.D. & Sue
John
2007 T@B
Rockford, IL
but still, that was an easy fix! Thank you dad, I o you one!
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
