I came home from a 5 hour trip two days ago. We ran with the headlights on all the way and every time I checked the dash, it read 14 volts. I will try switching the lights off a couple of times to see if there is any difference.RollingBnB said:Have you noticed the volt meter on your dash board going down to 12v after driving awhile? The truck ecm will see the truck battery as charged and reduce the alternator output. To ensure constant 14v sent to the trailer turn on the tv lights. That's what works for me. 2015 Silverado
I will have to try running the fridge at home on 12v with the the trailer plugged in to shore power to maintain the battery and see if I have a different result. I'll also check for any blown fuses. The 2017 does not have a cooling fan and the unit is vented outside with a lower and upper louver. It does get hot though.foxden said:How does the Norcold run on battery when not on the road? So far, I have only taken my 2017 on short trips but when at the site it ran about the same as with shore power. I have read much about the need to keep the T@b almost perfectly level to get the 3-way to work so is it possible that travel takes it out of level enough to create problems with cooling? Have you ever used propane while on the road and, if so, did it work well?
I haven't seen my display ever go that low. I haven't checked it on idling. I never ran the frig on 12V after someone told me how many amps it pulled and how inefficient it was on electric in general. Since I'm a weekend camper, I'd propane cool it down 24 hours prior to camping and travel with frozen water (and drink it during camping). This only works for weekenders like me.RollingBnB said:Ratkity I noticed the trailer runs about 1v lower than the tv so if my alternator output is reduced to 12.5v due to a fully charged battery, the trailer only gets 11.5v on the display.
