New Trailer Jack Wheel Conversion
larrygon
Member Posts: 255
My driveway is made of pavers. The plastic wheel rolls roughly over them and it is an up hill push to put the T@B in the garage. I looked around and found an eight inch pneumatic caster wheel. It will handle 250 lbs. I then took a square foot plate and attached the caster to it. I am now able to swap out wheels and roll the T@B almost effortlessly around.
The only real gotcha is that it will not lower far enough onto the tow ball, so I have to swap out wheels or use a jack when I am ready to hitch the trailer up. A small price to pay for convenience!
"Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
3
Looks like a nice solution to your problem. Not really fond of the plastic wheel either.
Sterling, VA0 -
If it does what you want it to that's what counts.
I love it when a plan comes together.- Hash T@B Fun
Your project got me thinking. I also hate those cheep hard plastic wheels. The pneumatic was not quite right for my need either. I did find a 6" direct replacement hard rubber actually poly wheel with ball bearing axel. Thanks your project helped be find an answer to a problem I did not even know I had.
- Hash T@B Fun
What brand and where did you purchase the poly wheel?0
Here you go!jdargis said:What brand and where did you purchase the poly wheel?
http://www.accesscasters.com/ac-2712-6-swivel-plate-caster-poly-on-poly-wheel-900-lb-capacity.aspx
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
Harbor Freight $14.99 with a 20% off coupon.
- Hash T@B Fun
2 -
Thanks for the info.
Jeff0 -
Gotta love Harbor Freight. We live literally blocks from one. My wife used free coupons for all of her stocking stuffers last year
Sterling, VA0 -
I initially thought about a poly wheel but I needed a pneumatic tire so it would not get stuck between the pavers. Still looking for an inexpensive 6 inch pneumatic tire caster. Harbor Freight had the 8 inch pneumatics for $14.99."Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.0 -
I had an 8" inflatable tire on my 5-wide Little Guy trailer and if you are in loose or sandy soil this type of adaptation is best since you can move the trailer around with ease. The issue as noted above is in your ability to raise the trailer up and get the tire on.....
I solved that issue by fabricating an additional stand (with attached jockey wheel) that was welded inside the trailer frame behind the tongue. This was pinned into place and once the trailer was jacked up high enough I unpinned the jockey wheel, rotated it down and pinned it back into position and lowered the trailer tongue jack down until all weight was on the portable jockey wheel assembly. this type of set-up is doable and the trailer is easily maneuverable in loose, sandy soil.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
Do you have any pictures?
- Hash T@B Fun
Tractor Supply has a pretty good selection of casters also.
The HobbiT@B, 2015-L, towed by a2014 RAM C/V0 -
Would this one fit as a straight replacement for the plastic wheel? If so, I think I would switch for the pneumatic tire too.larrygon said:I initially thought about a poly wheel but I needed a pneumatic tire so it would not get stuck between the pavers. Still looking for an inexpensive 6 inch pneumatic tire caster. Harbor Freight had the 8 inch pneumatics for $14.99.Ray and Vida Barrick
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada0 -
Most of the time with pneumatic wheel and tire combinations the 6" is referring to wheel diameter not tire. It's unclear about axel size 3/8 bearing is to small needs to be 1/2". Measurements are not very clear.
- Hash T@B Fun
Pneumatic tires work fine but if they loose air and they do over time they are useless.
- Hash T@B Fun
Also, looking at the specs, it has a 150 lb dynamic load rating, which the tongue weight of a T&B starts at around 150 lb unloaded.0
The little trailer jack wheel sank in the mud, so I purchased 2 additional wheels/bushings online and an 1/2 x 8" bolt locally.
Wow that is cleverMN_Jim said:The little trailer jack wheel sank in the mud, so I purchased 2 additional wheels/bushings online and an 1/2 x 8" bolt locally.
2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.0 -
Trailer jack training wheels!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
This still doesn't solve the issue of mud or an uneven surface. An inflated rubber jockey wheel that can handle the weight will spread out better and does distribute weight much more evenly.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0
Until it's not inflated
- Hash T@B Fun
2 -
@dalehelman, do you have the item # for the wheel from Harbor Freight? Side note: #1, holding tank mod is great, #2 cold air deflector mod for ac using old yard sale sign. Works great.0
HFT # 61651 if I remember correctly
- Hash T@B Fun
Access Casters also lists a 6" no-flat pneumatic (250lbs) that looks like a good candidate:
http://www.accesscasters.com/6anf62-6-no-flat-pneumatic-wheel.aspx2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)1 -
@dalehelman, thanks.0
Wow, your Amazon delivery is uber quick. Matter of hours. I am impressed.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Folks: I'm looking for reference item #'s or sources for any of the solid rubber "extra" 6" wheels. The HF reference number listed by Dalehelman takes me to an item which includes the caster. They list an 8" tire; but not a 6" (that I can find). The 6" solid tires I've found with random web searches turn up wheelbarrow tires rated for only 50 lbs. Thanks Team!!
2018 T@B CS-S; pulled by a 2010 Toyota Tacoma v60 -
Seems like this might work? http://shop.servicecaster.com/6-x-2-Phenolic-Wheel-p/scc-phr620.htm?gclid=EAIaIQobChMIgfDBh8vh1gIVD3F-Ch1IeAYJEAQYAiABEgKB0PD_BwE
Up grade thanks to trikepete.Dalehelman said:Your project got me thinking. I also hate those cheep hard plastic wheels. The pneumatic was not quite right for my need either. I did find a 6" direct replacement hard rubber actually poly wheel with ball bearing axel. Thanks your project helped be find an answer to a problem I did not even know I had.
https://m.harborfreight.com/6-in-rubber-heavy-duty-rigid-caster-61647.html - Hash T@B Fun
Is this kind of tire better than the original?Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI0
- 417 Service/Maintenance & Recall Notices
