replacing stabalizers with scissor jacks
atlasb
Member Posts: 584
Has anyone replaced the stabalizers with scissor jacks? Wonder if that is a problem lifting to level the 440. would the frame be able to support the lifted weight. not trying to get it totally of the ground, just use them to level.
I have replaced the rear stabilizers on my Outback 320. I have used them to lift the camper up enough to get a BAL leveler under one of the tires (on mushy ground) with no issues. I'm not sure if it would work with a 440 (or what model that is), but I don't see why not.Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
@Dalehelman has done this mod successfully. Check his mod posts(sorry, right now I can't find and link it for you.)2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
Here is the thread:
http://tab-rv.vanillaforums.com/discussion/3688/replaced-stabilizers-with-leveling-jacks/p1
Thanks pthomas 745 for finding and adding the link. I noticed in the link that Mike sent a email to Pleasant valley/ NU Camp requesting their thoughts on adding the scissor jacks. would be interested in their thoughts on adding to the 400. Did not see a post from them. Thanks again!
2018 T@B 400, 2017 Nissan Titan Crew cab0 -
Sorry for the newb question... What is the advantage of scissor jacks vs stabilizers?2018 nuCamp T@B 400 + 2016 BMW X1 tow vehicle0
I have stabilizer jacks on the toy hauler. They are rated at 3000# a piece. The instructions specifically say NOT to use them as levelers. It can bend the frame. Always level with tires and jacks.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
ratkity, After doing more research that is what I found also. Should only be used for stabalizing. I was under the misconception, that you could use them for leveling but find if not properly used and mounted, you can damage some frames. We have noticed some of the lesser trailers on the market do not include them, probably to keep the cost down.
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
