hello to all
as any one ever tried to install led dimer switch to control the ourside light or even inside light.
the porch light are in my mind and most of the time way to bright and most of the time only good to anoy the camper 1/4 miles away, or attrack bug and butterfly to camp.  (Ok, I might be exagerating a bit, but I think you get the picture).
i do not want to remove them, cause they could be useful to anoye the neighbors.  Just kidding again.  They could be usefull at time.
so a quick search as let me found theses.
http://www.ebay.ca/itm/Wall-Mounted-Sensitive-Touch-Panel-LED-Light-Dimmer-Controller-Switch-DC-12V-24V-/282393544296?var=581524707236&hash=item41bff78668:g:DDUAAOSwXYtYxmhoAny comment?
thank you for the link!
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
the link you provided works for bulbs type light. The ones on my 2017 T@G are made with LED strips and the rear galley light is also an LED strip inside a sealed enclosure.
so, might have to go with the dimer.
i will let you know!
so it might take me a while to go foward on this. Maybe next spring since bugs and flys season is pretty much over for us up here.
But for this one, I do not know.
Previous 2017 T@B S owner... c'est l@ vie
But still passionate about the brand!
