I've had some issues with the tail lights and running lights working intermittently and have been thinking that I want to rework all of the plastic housed crimped connections to soldered connections. What's been happening is that some of individual taillight LED's work some of the time and sometimes it clears up and they all work. I've had similar issues with the side running lights. I've cleaned the tv to trailer 7-pin connections a number of times with mixed results, sometimes that helps, but the problem returns. The fact that occasionally all of the individual LED's in the taillights do operate has me suspecting that I may have some faulty connections.
My question is can I run the 120V system in the trailer while I'm working on the 12V wiring to the running lights? I keep the trailer plugged into 120V while it's parked next to the house and, this being summer and all, it'd be a little more comfortable if I could operate the AC while I'm crawling over the benches to get to the wiring.
Thanks in advance for any help or insight you can offer.
0 ·
There is a sealed box under the tongue that you could use to check to make sure the wiring is giving you the correct current and voltage. (Be sure to seal it back up with water proof caulking after you have tested.).
So, provided you know exactly which wires to cut (or not cut in this case), chill away!
This problem 1st showed up during a recent trip to west TX & NM. I attempted cleaning the plug contacts and even added a mini bungee to try to tighten up the plug connection and at times most, if not all of the individual LED's, would work, but it's been hit & miss. I pulled one of the lights and realized that it was a sealed unit with an extremely short wire connection. I believe it will have to be accessed from the interior to cut the wire's loose for replacement. LED's typically are long-lived which led me to thinking that the issue was with the connections.
Thanks again for the info.
