What pressure are you using in the Steel Belted Radials on the 400's?
atlasb
atlasb Member Posts: 584
The radial tires look as though they are running low but the pressure is at 45+ psi.  The max press cold shows 50psi.  they are Nitrogen filled and only one place in our area has the nitrogen.  What pressure is recommended,  as I did not locate it in the owners manual?  thanks!
