We currently tow our trailer with our Toyota Tacoma 4-cyl truck and it works great. However, we are looking to sell our truck and get a car instead. Which cars will do the job comfortably? We have an eye on the Suburu Outback and Misubishi Outlander but would love to hear other's experiences and opinions.
Many thanks!
Greg K.
0 ·
2017 T@b 320 S
2017 Kia Sorento SXL AWD
Ottawa, Ontario
You did not give much information regarding what you are looking for, other than your two example vehicles, and a ball park tow rating. The more information you give us, the better suggestions we can give you.
Any vehicle with 3500 lb factory tow package (not after-market) can handle a T@B 320 plus gear.
If you go lower than that wear and tear on TV will be a factor as will power and speed especially in the mountains.
UK/EU caravan sites often show T@B 320's being pulled by sedans but they must be turbo's if 4 cylinder.
This one seems a bit extreme --
In my humble opinion, to tow even a T@B 320 (any model) with a vehicle that has under a 3500# towing capacity, and anything less than a 6 cylinder engine is pushing the limitations, and extremely taxing on that tow vehicle. Not only is it taxing on the motor, and transmission, but the braking system, and, in some cases even to the frame & suspension of the vehicle. If you're close to the limitations of the vehicle, you're only pushing your luck, especially in an emergency stopping scenario. Just my opinion, you, are in fact entitled to your own opinion. I would just rather err on the side of safety.
Ford 2.0L Ecoboost is a 4 cylinder turbo.
2014 model is 240 hp @ 5,500 rpm, 270 lb.-ft. of torque @ 3,000 rpm.
2017 and later models have an updated 2.0L engine with specs at 245/279.
Factory tow package is rated at 3500 lb with transmission and chassis to handle that load.
Yes towing will halve your mpg but that also means 26-29 mpg when you unhook and go site-seeing which we do a LOT.
On top of that we LIVE in the mountains.
As I mentioned above a 4 cylinder turbo sedan is a common UK/EU tow vehicle for T@B 320's and Ariba's.
As @Trailpixie said "Americans like to overbuild everything". I will add "overthink it".
Bottom line: If you travel light and understand the limitations you can tow a T@B 320 safely with an Outback and tow package rated at 2700 lb. Or you can go to the other extreme with a truck rated at 5000 lb or more. You'll likely forget the T@B is even back there. Anything in between is the sweet spot IMO. YMMV (literally).
If your favorite campsite is only a couple hundred miles from home and you'll visit there a few times a season, with some experience you will be fine with a TV with marginal capacities (2000#)
If your new trailer is an enabler for a country wide tour of National Parks you will want at least a 3500# rating for comfort,confidence and reliability.
Have Fun!!
2017 T@b 320 S
POWER to WEIGHT RATIO for TOWING
2017 GRAND CHEROKEE
2018 OUTBACK
2016 FORESTER XT
IMO:
Higher is better for stability and control.
Lower should be higher fuel efficiency
You can do the math
Have Fun!
At a minimum, you should have a tow vehicle that is capable of the trailer's GVW, in our case that's either 2700 (2800?) or 3500 LBS, depending on model and year (I believe all T@b 400s have a 3500 GVW) I know folks with Subaru's that rate at 2800 towing capacity and they do just fine. Of course you don't want to be screamin' over the mountains with that load, just take it easy.
2014 T@B CS Maxx
Martha Lake, WA
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
