Can anyone explain the small white plastic insert with what appears to be a drain hole in the bottom of the shower faucet. Seems to be the source of leaking after the shower has been used. I have heard some mention a modification to get rid of the separate Hot/Cold handles gets rid of the problem but why is it there in the first place.
0 ·
As part of this shower modification project, on Dale's suggestion, got an 8 foot hose for shower handle, Love it. I got a suction cup shower handle holder and mount it on the driver side of the tab when I want to have shower outside ( hose out the window). Love it for rinsing dishes or dog. Maybe even me if wife starts complaining louder.
Suction mounted hooks in assorted colors also available making any smooth surface an easy mounting place to hang things. Love them on the outside walls after camp is set up. No evidence of effect on T@B skin.
Markath, here's the post I did on the single lever faucet change out.
finally finished the shower faucet upgrade. I chose the American Standard Stratton Shower faucet
( $74.00 from Menards) , It was the only one I could find at the local big box
store that allows you to adjust the flow rate by moving the handle upward or
downward and the temperature left to right. So once you have the water temp set
you can shut off or adjust the flow
without changing the temperature. The fitting I used to attach the handheld
shower hose is a wall elbow from Delta part
#50560 ( $23.11 from Amazon). Thanks for the idea Dale, we are really
going to like this upgrade.
sorry about the view on the last pic
Where do you get them and how do you replace them?
I have an RV parts place 5-6 miles away from my house and got them there. I'm sure you can get them on Amazon.
How to replace? Easy, they are only plastic and with plastic threads, you screw it on a smidge over finger-tight. There wasn't even any teflon tape. Shouldn't need it with plastic threads. Careful not to cross-thread the little suckers (pun).
