 OneOleMan
                    Member Posts: 10
OneOleMan
                    Member Posts: 10
            I've not had a camper/trailer is several years, now it’s time to get back to camping and I’m not sure what will solve my pangs. I do know sleeping on the ground is too much for these 70+ year old bones. There are just 2 of us, my old 80# Aussie and myself so there's no need for anything large.
In looking I've narrowed my choices to the T@B Clamshell, the T@B with either the U or L Floorplan and an A-Frame pop up; all without a wet shower but with the outdoor shower and a port-a-potty. In the past I enjoyed boon-docking and imagine I would do some of the same with my new trailer.
Now a couple questions for the T@Bers who know best:
1 – The Clamshell has a 12V/110V refrigerator, when there are no hookups how long will a fully charged battery last running the refrigerator on 12V? Would I be able to get 2 days before re-charging it? I have a feeling for boon-docking one of the other T@B’s would be a better choice.
2 – How do others who enjoy boon-docking handle the fresh water needs? 5 gallons really seems quite minimal, maybe I’m wrong. The 19 gallon grey water tank should be large enough, though.
There'll probably be more questions later but this, at least, is a start.
Any suggestions will be appreciated.
Mike, thanks for the link “How to conserve water”. Many ideas there I had been aware of years ago and since forgotten. I now remember using Sun Showers, not only for showers but also extra water. Solar power is probably the way to go and if a flexible one could be safely attached to the T@B’s roof that could be a real plus.
I really don’t like generators, rented one once when with a group in the middle of the desert; danged thing was too noisy. One of my son’s has a small one he uses so perhaps I could beg, borrow or steal it from him for a week to give it a try.
Pat
J.D. & Sue
http://www.macandchris.com/RVBatteries.htm
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada
i saw your setup and it's what got me thinking about this. My T@B clamshell will arrive in March or April and I've read the battery is installed by dealers and not the factory. I'd like to upgrade the battery from the beginning and think the AGM might be the ticket since I've saved up some extra $$ for outfitting. I also believe solar will be a must but I'm torn between Renology and Zamp. Totally new to all of this and am wondering how wiring works if the battery(ies) are inside. Does it mean drilling holes to pass through wires?
I like the idea of Renology for convenience and not worrying about theft but worry about positioning. Your post was the inspiration for an entire afternoon of learning more about batteries and solar. But not sure I'm any closer to a decision, no perfect answer and lots to think about!
the Group 27 AGM feel like what I want though I had only considered 1 and HADNT thought about balancing weight. Thanks for that! How did you wire them?
When wiring for solar I will use the existing wiring in the tongue box with no problems. Because we are working in a 12 volt system be careful of voltage and current drop over distance - be sure and use large (low gauge) wires wherever possible. It is possible to mount a waterproof connector on the wall of the trailer to be closer to the battery.
I would also recommend a battery monitor be installed that gives to the information of amps in, amps out and % of charge remaining in the battery. I had a Trimetric TM-2030 installed by a professional solar installer. A good monitor gives me peace of mind knowing how much fuel is in the tank. A lot more precise than measuring voltage in the system.
Toronto ON Canada
Next time I'm in there (going to replace solar charger anyway), I'll try to remember to take a couple of photos.
Nice part is that each battery is over the axle, neutral on weight distribution, and I reduced the tongue weight pretty significantly when I relocated back.
Used up a little storage on the left hand wheel well area, but the right is generally taken by electrical anyway so wasn't a significant loss of storage space.
As to wiring from the solar, I did drill a hole into the electrical area to get the cable in for my solar.... just coated the hole and haven't had any issue. Since my solar is permanent, I ran the solar connectors along the inside edge of the bottom until I needed to move them into the t@B. Since you have ZAMP connector, not sure of the approach you would need to take, but since it is prewired, can't imagine that you'd need to do too much to modify to your needs.
Are your battery boxes secured to floor ?
Any electricians can chime in and correct me...
Leeh22, Goal zero actually makes an MC4to SAE cable. How are you planning to set up your Renogy panels, permanently or keep them portable? If portable, how will you set them up?
Is there any "better" brand these days?
Also, is the charging curve of the Tab's converter appropriate (or close enough) for the AGM batteries? I know I had to look into it when I installed the Optima in my old Ford tractor, to be sure the tractor's generator was ok with it. It turned out it is, but there is a difference between 'wet' batteries and AGM.
mil spec...standard shape and size...check them out...made in USA. Anyone using this brand ?
