I want to replace the kitchen faucet in our 2016 T@B S. It isn't tall enough to get larger pots or our filter dispenser under, and I've noticed that the black seal between the faucet base and the counter is broken so I'm concerned about water leaking into the cabinet.
If you've replaced your faucet, how do I go about it? Are there any special tools or techniques? Will a standard bar faucet work?
0 ·
Alan & Patty
Southern Az
Alan & Patty
Southern Az
Kingston KS8198DL
Here is the Amazon link:
https://www.amazon.com/gp/product/B000F692P8/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
2011 T@B
Rockingham, NC
https://www.faucetdirect.com/moen-5995-single-handle-pulldown-spray-bar-faucet-with-reflex-technology-from-the-arbor-collection/p1329134
Alan & Patty
Southern Az
The bathroom faucet I bought was perfect (height and bend). One thing I ran into was the holes weren't perfectly 4" apart. I needed 2mm more room on each side for a perfect fit. It wasn't hard to do with a scraper or good file (tape the counter with painter's tape!!). Empty the cabinet underneath. Easier to clean the filings! Still only a 30 min job, even with the filing. Worth it!!
https://www.amazon.com/dp/B092YSBW7X
