Couple of questions.
Is this the model?
If so this info says you need an inverter to run. You say it runs on 12V. What am I missing?
Thanks so much!
Plug into your vehicle and play!
The Tailgater® receives its power through the coax connection with the DISH receiver. The receiver will need to be plugged into an AC power outlet. You can use an AC/DC inverter to power your receiver, Tailgater® antenna, and television off of your vehicle’s DC power supply (12V power outlet). If your television is rated at more than 100 Watts, you may need to connect your inverter directly to your vehicle’s battery since most vehicular 12V connections are only rated to 150 Watts. If you plan to watch TV for more than a few hours, be sure to start and run your vehicle for a few minutes. This is required in order to keep your vehicle’s battery healthy. Please note that most vehicles, when turned on, temporarily shut off power to all connections, meaning that you may have to setup your Tailgater® antenna again in order to resume viewing satellite TV. If convenient, a portable power generator, portable power pack, or alternative accessory battery may be better options for operating your system and can help preserve your vehicle’s battery life.
