Smullis7
Member Posts: 221
I learned another lesson in prepping the camper to go. I was traveling with a friend this weekend and let her take care of hooking up the chains, emergency brake and 7-pin connector for the braking system while I dealt with securing the inside and packing the power cables, chokes, blocks and various items. I should have checked it myself, but didn't...in my defense, I was hungry and needed more coffee...which was our next stop. We start moving and the rear driver's side tire locked up. Now...not thinking straight due to my weakened condition...I immediately think it's the 7-pin or some muddy rocks are lodge in the tire following an unplanned wrong turn excursion the day before that involved mud and cows (another story). I reset the braking module, unplug and replug the 7-pin. I even crawled under the camper and got it into my head to remove the tire. Fortunately, my husband, who I had called to let him know I might have to move to Lindsborg, KS since the camper wouldn't roll, was thinking with a well-caffeinated brain and reminded me about the emergency brake. Lo and behold, my friend had it all balled up in the chain and had pulled out the connector pulling on it. In her defense, she normally travels in a 5th wheel and had no idea what the little wire was about. I plugged it back in and off we went...much happier and with a new resolution to just take the time to eat breakfast and have a couple cups of coffee before we break camp again! On the bright side, the emergency brake definitely works, and the cable could be removed as a theft preventive measure, if needed.
The breakaway cable goes to a relay switch (little black box) connected to your T@B battery and electric brakes. When the cable gets yanked that pulls a plastic pin out of the switch causing a circuit to close and brakes engage. Under normal conditions that would mean a runaway trailer.
You should periodically test the relay switch to confirm the brakes lock up as expected.
Step 1: Disconnect 7-pin pigtail connector between TV and trailer.
Step 2: Yank out the relay pin by tugging on the breakaway cable.
Step 3: Attempt to drive forward; trailer wheels should be locked.
Step 4: Reinsert relay switch pin (make sure it's flush); reconnect pigtail connector.
Never tow with your battery cut-off switch in "off" or the breakaway switch will be useless in an emergency.
Also make sure the cable is free and clear while towing, not wrapped around the chain or otherwise hindered. On the other hand make sure the cable isn't dangling on the ground.
The proper amount of slack is just short of chain slack. Why? Because the breakaway switch will prevent the trailer from slamming into your TV should the hitch jump off the ball for some reason or ball fails. If that happens your trailer can run into the back of your TV when you hit the brakes unless the breakaway switch activated to slow the trailer or you think fast and reach down to activate your TV brake controller manually.
IMPORTANT: Never leave the pin out of the switch for a long period of time or the switch will melt.
See: https://www.escousa.net/technical-documentation/break-away-switch/
Other trailers may have their breakaway switch wired directly to the battery terminals, but this is not the case with the T@B. (At least not as of 2015.)
So, it's worth repeating for new owners: if you tow with your battery disconnected, your breakaway brakes will not operate in the event of a trailer separation!
However, it won't do you much good once your free-ranging trailer yanks the pigtail out its socket!
I now know what is the utility of the wire. Even my dealer was not able to realy clarify this, so I did not know out to properly adusjt the lenght of the wire. And since I modified my thong on my T@G, I was wondering how to use that wire.
now I know!
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Make sure the cable is free and clear and not caught up on something.
On our used T@B a sway bar (since removed) had been installed with long bolts that protruded in the way of the cable.
Once out you will notice the pin only goes back in when turned a certain way.
It should not be difficult to pull out or insert back in.
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
