Winter storage
TTTabTTTab Member Posts: 100
My battery was new in April.  I just moved my T@B to an RV storage lot for the winter.  There is no electricity. So what do I do about the battery?  If I leave the battery on off switch to off will my battery be OK in the spring?
2015 T@B M@x S silver and white
tv 2010 Lexus RX350 Matador red
    Batteries do self discharge even if you have turned your battery cut off switch to "OFF" and isolated it from phantom draw.  You are likely to come back to a dead battery in the spring.  If you have the standard leaded battery that came with the Tab, best to remove it, store it at home in a vented area and put it on a charger.
  • TTTabTTTab Member Posts: 100
    It is a wet cell battery, marine battery???? The dealer replaced it this spring.  I assumed it would be dead in the spring and thought I could just recharge it.  I live in an apartment. I should have just sold the T@B  My health has not allowed me to travel this year and everything is such a struggle.  I will see if someone can help me pull it and if they will store it for me.  I will then need to purchase a charger
    Sorry TTTab.  All batteries need to be kept charged to prolong their life and wet cell batteries need to be maintained with distilled water, too.
