Maybe something is missing in the wiring; relay, trailer flasher, fuse... Someone with the same car should be able to help (or there is always the dealer). ( Jeep Grand Cherokee Summit 3 L diesel)
T@B trip wherever New surprises everyday See beautiful world
Dealer(boooo) lol. I get battery at the fuse box, replaced fuse no good. I loothe the idea that the Perez is a break in the wire from the fuse box to the 7 pin on the TV. Got a buddy who's a mechanic with more patience then me coming by today to take a peek...
I hate to even admit this but I thought I had trouble with the running lights on mine a few weeks ago. The Jeep Cherokee has the knob for the headlights right in line with my left knee and I didn't realize that my knee had turned off the headlights. Because I was only driving during the day, I didn't notice. Without those, the running lights were not powered. Now I know!
2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX
I believe I have found the culprit. As there was no power at the TV 7 pin, but I have power at the fuse box, it HAD to be wiring from fuse panel to 7 pin. I just couldn't believe it to be on a 3 yo truck. Well...chasing the wire harness, I found a section of the harness that had been rubbing against the rear right upper control arm; exposed and corroded copper. It's very in accessible to work on, so I'm taking the truck to my buddies shop to get it up on the lift. I hope to have resolve by this time tomorrow...
It is now! It was the warn wire I found yesterday, wasn't easy to get to, but spliced & repaired! Put a small piece of rubber hose around the problem area to prevent it from happening agin!
Nice. It's always great to find the obviously correct fix, when previously it was a bunch of question-marks! Wonder why it was free to rub on the suspension in the first place, on a TV so young. Aftermarket installation?
Chan - near Buffalo NY 2014 S Maxx 2011 Tacoma 4cyl ... edit: 2022 Tacoma 6cyl - oh yeah! A_Little_T@b'll_Do_Ya
@4ncar, Glad to hear you got your mystery solved! I've used pieces of rubber hose slit down the center & placed on sharp pieces of metal to protect wiring & rubber hoses myself before. Nice simple solutions to avoid a not so nice situation later! Good thinkin'! @ChanW, There have been several times I've asked myself the question..."Now WHY did they put it there, so close to THAT????"
2016 T@B MAX S-aka: WolfT@B TV: 2006 Chevy Avalanche LT Z71 aka: WhiteWolf, or 1972 Chevy Custom10 P/U aka: SnarlingWolf Spokane, Wa. Eric aka: Lone Wolf
@ChanW & @ericnliz it was/is clearly a manufacturing “issue.” The wire harness was in its stock wrap with stock securing means. It was installed “high & tight.” The just seemed to be a sag at the wrong spot, and thus the rubbing.
For wire wear issues, I usually stick a high temp repair tape between the place and the wire and use heat-shrink splicers. Glad you found the rogue wire!!
See beautiful world
See beautiful world
