Zamp reverse polarity
Mega
Member Posts: 69
If this is in fact reverse and I connect Go Power solar (I noticed the indicator lights on the panel are not lit up) will it wreck the battery? If so damage is probably already done.
Probably not, but I'll let the experts weigh in. Be specific: what did you plug what into?
Towed by 2014 Touareg TDi -
I'm using an 80 watt Go Power portable solar panel and plugged it into the supplied plug in on the Tab. Should I just be using allugator clips and connecting directly to the battery?
Yes, connect directly to the battery if you do not have a Zamp.Verna, Columbus, IN
Chan w brought this to our attention 2 years ago. Go to Amazom.com and search for "SAE reverse polarity connector." $10. I use it with my battery tender.2016 Outback 320
Thank you
I learned that the reason Zamp reverses the polarity at tge plug is because they do not reclverse it at the solar controller and most solar controllers have the resversed polarity built into the controller. I thought that was an interesting little tidbit.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
