We have a T@B Max S, are now using dual 6v golf cart batteries and have a 100w suitcase Renogy solar panel that we connect using the Zamp plug. We are looking to add and mount flexible panels on the roof. Probably two 100w panels. The Renogy suitcase panel has its own controller. The questions that we have are;
1. would it be preferable to have the suitcase panel and the new flexible panels all run through the same controller?
2. is there any reason we couldn't leave the Renogy on one controller and the new flexible panels on a different controller?
3. if we used a single controller what size would we need (in amps)?
Our hope is that the flexible panels will supply the necessary power and the suitcase will only be necessary as a backup. The single suitcase doesn't really do the job for us as we normally are away from the campsite during the day and don't like to leave it unattended (theft concerns).
0 ·
2. no I do
3. there are calculators for to determine that.
I've found solar to be a dish best consumed slowly, and I readily admit I am not very knowledgeable about the electronic intricacies of the controllers. Any insights?
T@BMahal
'04 #100
