Question about wetbath
We are considering a tab outback.
How is the durability of the tub surround in the wet bath?  Is it just wall paper or is it plastic?
anyone had any separation from the wall due to moisture?
    I have been using it since 2014 and no issues, whatsoever. I assume it is some type of water resistant paper. I use a squeegee and get the excess off after showering.
    I can only think of 1 Tabber who had to have an edge of the wallpaper reglued.  It is very resilient.  It is a good idea to squeegee or wipe the walls down.  Also helps jeep the humidity down in that space, unless you are out in Arizona, then it may not matter as much.
