Outback & TV Ball Height
IslandJoIslandJo Member Posts: 60
I have a new T@b built on an Outback axle. The top of my ball is 16" off the ground.  If I put a level on the front of the T@b it looks like the hitch is at 20". I have a heck of a time getting the TV & T@b uncoupled. The top of the hitch slides back without a problem but getting the hitch & ball apart is the problem. When I raise the wheel on the T@b the back of my TV goes up with it.
Do I have the ball too low? Should it be at 20"s? This is my 1st time pulling anything so this is all new. Thanks for your help.
2018 T@B CS-S on an Outback axle
2017 Toyota Tacoma with tow package
Pacific Northwest
  • hymiehymie Member Posts: 150
    We have a 2017 outback. It is level with the top of ball at 18".
    James & Jacquie     Almonte, Ontario
    2016 Jeep Cherokee & 2017 T@B Outback
    Your Outback axle gives you about 4 more inches of clearance.  Not sure if that directly translates to 4 more inches higher at the ball, but I would think your ball should be higher than 16.  What is your TV?
  • dsatworkdsatwork Member Posts: 744
    I know that others have had issues getting the coupling off of the ball and I'm sure that the angle is critical for this to work properly. You should put a level on the trailer and check to see if it is level when connected. If not, I would start there and see if that solves your problem. You should be pulling your trailer level regardless.
  • IslandJoIslandJo Member Posts: 60
    @SAM I have a 2017 Toyota Tacoma.
    Pacific Northwest
    Who pulls their Outback with a Tacoma?   Jenn G. you have the raised axel, what is your ball height, please?
  • GrandmasKidGrandmasKid Member Posts: 163
    We tow our 2017 Outback with a Highlander Hybrid and our dealer flipped the ball mount over to achieve 18" to the top of the ball.
