Greetings everyone, longtime reader and new T@B owner very excited to finally join and contribute to this awesome community!!
Over the past 2 days I just followed all owners manual procedures for sanitizing the freshwater tank on my 2017 320 S Max, however am having a tricky time getting water system back to normal after flushing the freshwater tank a few times after the bleach sanitization process. Keep in mind this whole process is only using the fresh tank onboard system, and at no point have I hooked up to city water.
My main issue seems to be unusually high water pressure coming out of the sink faucet, especially when initially turning the faucet from off to the on position. I seem to have gotten all the air out of the lines just fine, but I find myself having to be extremely delicate with the faucet in order to prevent high pressure water splashing everywhere in the kitchen area. The pump switch is on at this point, but the pump only runs for a bit when using water as per usual operation.
The pressure buildup is so high that a couple times this morning I slowly opened up the faucet knob all the way, and the small faucet head nozzle actually BLEW off and into the sink!! Luckily it doesn't have threads on it and only uses a rubber o-ring, so it simply snaps back in place (maybe this is a safety feature?)
The other thing I am slightly concerned about is when the pump is running and pressurizing the system, I hear a gradually increasing hissing sound for a few seconds before it turns itself off. I don't seem to remember this happening previously but I can't exactly remember. Its not a super loud hissing sound but I just wan't sure if it was normal operation or not.
Has anyone else had issues with their freshwater system pressure being extremely high, and even blowing the faucet nozzle off at times?
2017 T@B Max S
0 ·
J.D. & Sue
New surprises everyday
See beautiful world
Could be a partial obstruction post pump or even in the sink faucet line. When I checked this morning the shower head didn't seem to have the same pressure buildup issue. Because the faucet head nozzle kept blowing off, I also wonder if the tiny little holes in the nozzle are restricting flow and causing the pressure build. Didnt look like any of them were clogged but I'll remove the nozzle tomorrow and retest.
Heading to Big Basin State park for the weekend so will have plenty of time to try and track this down even further.
2019 Ford F-150 3.5L Ecoboost with Long Bed
And agree, try hooking up to the city water connection and see what happens and if that changes things up.
After using the shower the second day and the Fresh Tank showed 30%, the pump would run endlessly without shutting off. I was turning the pump on and off manually at that point to build some pressure for the sink only when needed. Shortly after this, the water pressure started sputtering with air indicating we were abut to run out of water. Weirdly when it finally lost most of its water pressure the fresh reading still read 28% full.....
I had learned from the previous owner that when the water tank is around 30% or less full, the pump has trouble building full pressure and continues to run endlessly, so I knew to turn it off manually at this point. However I was definitely a bit perplexed as to why the tank was seemingly empty with the reading at 28%...
