Where is my Glycol Tank
LHough
Member Posts: 3
I have a 2014 T@b. I can't see the glycol tank anywhere.
If you have the inside kitchen shower model, the glycol reservoir should be in the rear driver’s side under the long shelf board. You’ll need a #2 square drive screwdriver or bit to remove the screw holding the board in place. The minimum and maximum lines are angled on the left back corner. Use a Sharpie to highlight the lines and use a small mirror to check the level.
If you have the CS-S (Clamshell shower) model, it will behind the cargo door behind the toilet. The Sharpie and mirror tip apply here, also.Verna, Columbus, IN
I don't have an inside shower and I don't have a Clamshell either. Thanks for trying to help.0
Which model do you have?Verna, Columbus, IN
We have a 2014 T@b Q, inside kitchen, no bath, and the glycol reservoir is where Verna has indicated. See photo.
Happy Trails,
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
Noob question. I have the same model and am wondering if the Alde is a closed loop glycol system that can be operated on heat mode only when the water tanks are drained (winterized)? Would like to have heat when boondocking In winter. What are settings on 3010 with slide controls?Dennis and Mary Jo
North Carolina
2015 T@b Max Q1 -
norwood, your cabin heat via the glycol loop can be operated all the time - in camping season when using hot water and after you winterize and have a drained Alde Hot Water Tank.
Sliders left to right - A, F, I then adjust temp with knob. Do you have the Alde 3010 Manual? It has a picture of the control and directions.
http://www.alde.se/usa/support/manuals-downloads/manuals/
Understood. Some of the explanation in the manual is obtuse. Took me multiple readings and using other sources to figure it all out.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@norwood it is also helpful to be half contortionist!
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0 -
A small mirror helpsVerna, Columbus, IN
@Verna, Is the small mirror for seein' what yer face looks like while yer doin' the "contortionist" moves @Homebodyatheart mentioned?
Oh, for the hard to see places.......got it.
Eric aka: Lone Wolf1 -
It's called T@B yoga! Discovered by people whose lid on their bin doesn't stay up in a windy cold night at 3am and they have to change out their empty propane tank!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)2
Can someone tell me where the reservoir is for the 2018 320 S? I don't see anything in the hatch behind the toilet. Thank you.Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S0 -
@dsfdogs, driver’s side rear panel. You will need a #2 square drive (Robertson screw) to remove the screws. There is a recent photo here of where it is. Do a search of reservoir and you should come up with the photo.Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”1
