External Jerry Can and Shovel Mount for Outback?
CincyKid
Member Posts: 83
About to pull the lever on a new 2018 T@B 320S Outback - has anyone added an external Jerry Can for more water to the outside and is there a solid spot to attach it? For the shovel I see there are shovel mounts that would like attach to the back of the Yakima rack.
CincyKid
Cincinnati, OH
A front aluminum rack would accommodate a Jerry can.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
@CincyKid, we use 2 6 gallon water jugs and just ratchet strap them to the Outback platform. Usually only carry 1 full and the other tossed on the bed as we travel.John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
Lots of different things can go on the front rack. Here is a thread with options for cans, etc.
Towed by 2014 Touareg TDi -
I think you could probably a fix a Quick Fist for a shovel mount.
I have a 2018 Outback in Florence. Where in Cincinnati are you? (Assuming that CincyKid is short for Cincinnati Kid)
2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
kybob.. I`m in butler county. north of cincy.. no outback but 2017 cs-s max.. going to nucamp 2018 ?2017 T@B CS-S Max ... 2020 Honda Ridgeline RTL-E
- 916 Introductions
- 72 Teardrop Groups & Links
