Covering the T@B and humidity
Bill_Cochrane
Member Posts: 103
I will be covering the T@B for winter with a heavy vinyl tarp since I cannot get a woven polyester, breathable fabric one at this time. $$ Has anyone experienced excessive humidity using a tarp in a humid environment ( Vancouver BC is very wet throughout the winter). I plan to place a dehumidifier in the trailer for the entire winter.
side note: anyone selling a PahaQue Outb@ck cover?
2017 White with Black T@B Outb@ck, Max S ( rec'd on May 2nd, 2017)
TV is a 2017 White Honda Ridgeline, Detroit Auto Show North American Truck of the Year Love it.
Have you looked at the Classic Accessories version? Very affordable and appears well made. Be careful with the vinyl tarp - there have been reports of wear of the Tab gel coat.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Wear of the Tab gel coat? Really, I'll have to research that; thanks Sam.
If it helps any I bought the Classic Accessories cover from Walmart.com for $76 and have been really happy with it. They make one specifically for the t@b.
They make models that fit an S model Tab and a CS model Tab.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thanks folks. Hwever, Walmart Canada does not have the S and CS cover you refer to plus I have an Outb@ck so I expect that cover may not fit over the back rack in any case.But they do have a Classic Accessories OverDrive PermaPRO Deluxe R-Pod Cover, which Fits 18' - 20' RVs. Has anyone tried to fit this on the Outback? It may be a bit baggy but it might do the trick.2017 White with Black T@B Outb@ck, Max S ( rec'd on May 2nd, 2017)
@Bill_Cochrane @Donnab posted this some time ago: Walmart.com
classic accessories polypro 3 teardrop trailer cover
item number: 0005296302433
if I remember correctly there are different choices so make sure you pick one that states T@b
she has an outback (boondock)John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
@Bill_Cochrane And here's a post from @clinck although I don't remember what edition T@B he has. Walmart.com
if I remember correctly there are different choices so make sure you pick one that states T@bJohn, Judi, Guinness & OD in PDX
I purchased ours on Amazon.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I only got 11 months out of our polypro 3 version of the cover, it rotted from UV and wet weather here south of Seattle. I now have the ripstop version from Classic accessories, and it looks like I'll get maybe 2 years out of it, it's faded but structurally intact after about 9 months. I've posted this info before, but searches don't seem to work very well.
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620 -
Thanks for this discussion everyone. db_cooper, there are 3 sizes at walmart with the riptop version. Do you remember which size you got or better yet the walmart item number? I have had my T@B since 2016 and have never covered it but this sounds affordable. In Durango we have snow and ice and lots of sun (even in winter) so am thinking it just needs to be covered for lots of reasons.Barbara in Durango... T@B Max S 2015...Red & White... pull with 2016 Toyota Forerunner
Walmart CSL2409. Did not know they made this version.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio -
Sweet sale of same item for much less.
https://www.hayneedle.com/product/classicaccessoriesoverdrivepermaproteardroptrailercover.cfm?ltype=child&tid=CAI680-2
Check this out.
SAM, i have a 2015 S model of T@B. (not teardrop or clam). There are some sizes to pick from on the hayneedle link. My mind is not cooperating to pick the correct size. Which size do you suggest? thanks! I think this may be my solution.Barbara in Durango... T@B Max S 2015...Red & White... pull with 2016 Toyota Forerunner
The Hayneedle site lists some odd dimensions (150 x 75 x 47). Went back to Walmart and their price is $119 for the Classic Accessories Permapro that fits 10 - 12 ft trailers. That is the one you want. 80-399-161001-RT. Now I see Amazon has it for the same price and no shipping with Prime!
https://www.amazon.com/Classic-Accessories-80-399-161001-RT-PermaPro-Trailers/dp/B071WY3G5Y/ref=sr_1_1?ie=UTF8&qid=1511821436&sr=8-1&keywords=Classic+Accessories+80-399-161001-RTSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 916 Introductions
- 72 Teardrop Groups & Links
