If you have the inside kitchen shower model, the glycol reservoir should be in the rear driver’s side under the long shelf board. You’ll need a #2 square drive screwdriver or bit to remove the screw holding the board in place. The minimum and maximum lines are angled on the left back corner. Use a Sharpie to highlight the lines and use a small mirror to check the level.
If you have the CS-S (Clamshell shower) model, it will behind the cargo door behind the toilet. The Sharpie and mirror tip apply here, also.
Verna, Columbus, IN 2021 T@B 320S Boondock “The T@B” Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”
Noob question. I have the same model and am wondering if the Alde is a closed loop glycol system that can be operated on heat mode only when the water tanks are drained (winterized)? Would like to have heat when boondocking In winter. What are settings on 3010 with slide controls?
norwood, your cabin heat via the glycol loop can be operated all the time - in camping season when using hot water and after you winterize and have a drained Alde Hot Water Tank.
Sliders left to right - A, F, I then adjust temp with knob. Do you have the Alde 3010 Manual? It has a picture of the control and directions.
@sam thanks for the info. No, I didn’t have the manual, but I do now! I am cautious about pushing buttons and turning knobs until I know what I’m doing.
@Verna, Is the small mirror for seein' what yer face looks like while yer doin' the "contortionist" moves @Homebodyatheart mentioned? Oh, for the hard to see places.......got it.
2016 T@B MAX S-aka: WolfT@B TV: 2006 Chevy Avalanche LT Z71 aka: WhiteWolf, or 1972 Chevy Custom10 P/U aka: SnarlingWolf Spokane, Wa. Eric aka: Lone Wolf
It's called T@B yoga! Discovered by people whose lid on their bin doesn't stay up in a windy cold night at 3am and they have to change out their empty propane tank!
@dsfdogs, driver’s side rear panel. You will need a #2 square drive (Robertson screw) to remove the screws. There is a recent photo here of where it is. Do a search of reservoir and you should come up with the photo.
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
North Carolina
2015 T@b Max Q
http://www.alde.se/usa/support/manuals-downloads/manuals/
North Carolina
2015 T@b Max Q
Sold 2023 Tab 400
Sold 2018 T@B 320S
