@RollingBnB I tried to adjust the valve. Where it said to move the knob out to the side I just pulled it towards me once the screw was loose? Is that right? I turned it some and re tightened as it said. gooddogs74 said:@RollingBnB I tried to adjust the valve. Where it said to move the knob out to the side I just pulled it towards me once the screw was loose? Is that right? I turned it some and re tightened as it said.
Man! That never worked in History class!! Which means, I'm doomed to repeat it (the class and History in general).ChanW said:@Homebodyatheart, I'm pretty sure that they've proven that when falling asleep with a manual on your lap (or preferably, on your face), you will absorb the information contained in said book, automatically while you sleep! So you're fine with that method.
I'm thinking that's how @ericnliz does it anyway.
@Homebodyatheart, I'm not REAL sure, but stuffin' your pillow case with manuals MIGHT not be the answer!
