We're wanting to upgrade our TV. We have a 2017 T@B 320 S Max Outback and a 2014 Dodge Grand Caravan with 90,000 miles on it. The van pulls our trailer just fine, but we are worrying that we are risking the transmission going out. It's rated for 3500 lbs., and we put most of our supplies in the van. Also, we would like to upgrade to a larger trailer in the next year or two, probably a 400 or LG Max, so we want something that is rated higher than 3500. Another factor is the small garage in our 1950's house. We would consider a full-size pickup but it won't go in our garage, so we've narrowed it down to a mid-size pickup, double cab and short bed. We want a pickup so that we can still put our supplies in the back, and also because we would like it to keep it for a long time. We are going to buy used, probably 2015 or 2016. I've been seeing mention of "tow packages" in this forum, but so far I've only found one complete tow package and that's on the Toyota Tacoma, so right now it's in first place. The Toyota tow package is as follows: "It includes a class IV receiver hitch with the trailer wiring but most importantly it includes a transmission cooler, engine oil cooler, 130 amp alternator and heavy duty battery. With the tow package, the Tacoma can tow as much as 6,500 pounds." I can't find anything like this with any other companies. Is anyone aware of other companies that have a similar towing package? Also, does anyone have a recommendation for other similar vehicles to check out while we're trying to decide? We did look at the Chevy Colorado, but the tow package is just receiver and wiring harness. The turbo diesel is what increases its towing capacity and our diesel mechanic son put the kibosh on that. Any info will be appreciated!
0 ·
Do a little more research on the Colorado and Canyon, then take it for a test drive, before ruling it out.
Gail & John
Gail & John
Gail & John
There is a brake controller available from the factory. I'm not sure if it is now standard with the tow package or not. It may or may not be a standalone option, or tied to trim levels. I know it was not available on 2015 V6 trucks. The brake controller looks like this:
http://image.trucktrend.com/f/134074991+re0+ar0+st0/2016-colorado-canyon-diesel-trailer-brake-controller.jpg
In 2017, the Canyon and Colorado got a new V6 engine, and 8 speed transmission, instead of the 6 speed in the 2015-2016. The horsepower and torque ratings are very similar to the 2015 & 2016 trucks, and the displacement is the same, at 3.6L. However, there are numerous changes, and new features like cylinder deactivation. Although the numbers are very comparable, drivers seem to report that the 8 speed transmission tuning is much better than the tuning of the 6 speed, and the truck feels quicker and more responsive.
I've test driven a 2015, and a 2017. I thought they both drove well. I have not towed with either though. I hang out at Colorado Fans a lot, so may be able to answer more questions if you have them.
I have a 2008 GMC Canyon, which is totally different from the 2015+ models, but I am a big fan of midsize pickups. I intend to buy a newer (2015+) Colorado or Canyon as my next truck.
Gail & John
Alan & Patty
Southern Az
PS: That is not to say your son hasn't done more work recently on diesels! Stuff happens to a car no matter what engine.
Gail & John
Gail & John
Gail & John
Gail & John
