We are new T@B owners and have just purchased a 2018 Toyota Highlander to pull it. The T@B has a 7 Pin Electrical Connection, but unfortunately, the Highlander has (only) a 4 Pin Connector. I have installed a 4/7 Pin Adapter to the Highlander and the lights, blinkers, and brake lights work fine. I am now only in need for a 12 Volt source to hook up the (black) lead to the 7 Pin Adapter to provide for the continuous power from the Highlander to the T@B. This will provide for battery charging in the T@B while traveling and a backup battery source while in camp. Has anyone had this connection made in a Highlander? Ideally, I'm looking for a continuous 12 volt source in the back of the vehicle so I don't have go through the fire wall for a direct line from the battery and tear apart the interior to run such. I can, of course, take it to my T@B dealer to have it done, but if there is an easy source in the back, I'd rather do it myself. Anyone?
0 ·
While the T@B isn't a huge trailer, it's heavy enough that you want those brakes operational. It may even be a legal requirement in some places. To use the brakes you will need a brake controller and have the tow wiring upgraded in your Highlander.
You might be able to "cheat" by using a wireless brake controller. However, I don't have any firsthand experience with these--hopefully someone else will chime in with some advice if that is a possibility for you.
Suggest you visit your Toyota Service Department not your T@B Dealer for help or installation for the 7-pin wiring. Toyota will know your vehicle wiring.
I've not been able to locate any Highlander Wiring Diagrams on 'the web" and you would be working blind without that type of reference material.
Your Highlander Owners manual does have two interesting notes:
a) For trailers over 1,000 pounds trailer brakes are required. You do need to add a electric brake controller to your set-up.
b) For trailers at/over 2,000 pounds a sway bar is required. Now user experience (Highlander owners on this forum) might say that is not needed but Toyota believes it is.
The website etrailer.com has lots of good info.
2017 T@b 320 S
2017 Kia Sorento SXL AWD
From etrailer, here's some info on trailer wiring for a 2017 Highlander, which I assume would be similar to the 2018.
https://www.etrailer.com/question-200706.html
I am not sure what you mean by a backup battery source. If your Tab battery is significantly depleted you would need to run the TV quite a while to recharge your TaB battery. Also, keep in mind, the after market charge lines that are installed without an isolation relay are always hot. So, if you stop for sight seeing for an extended time, you can potentially draw down your TV battery. If you have your charge wire done in an auto shop, they can install an isolation relay that cuts power when the ignition is off.
Regarding the brake controller: I agree with Jason. We have the Prodigy RF Brake controller. No further wiring needed. Pretty much plug and play.
They installed a 7 way connector beside the hitch and installed a Tekonsha P3 brake controller. You have electric brakes in your 2016 and need some sort of brake controller. They also ran a fused heavy gauge 12v line from the battery back to the appropriate pin on the 7 way.
However, you originally asked about charging and a 4 pin. I ordered a 7 to 4 pin adapter and added a 2 wire piece of cord which alligator clamps directly to the battery terminal. I can send a link and pics if you are interested. I use it when my buddy with a 4 pin tows my T@B with his pickup. It does seem to charge the T@B battery. No brake control with this setup, though.
