We are heading off to Big Sur this weekend and since we did not like the big table and installed a small table we need to be able to set up a full size bed. Dragging in the big table to set up the bed is just not an option, we tried that.
As many others have done, I did the slat thing. I could not find matching Birch so I went with poplar. It comes pretty darn close to matching.
I went with stainless steel hardware.
I used pine 1x12's since they don't show.
A nice feature is that our table breaks down in seconds and stores under the bed slats when the bed is made up.
A couple of question. Where do you store the slats when not in use? Also, hard to tell from photo, is the passenger side cleat just above the warm air outlet slot?
The heat slot is partially blocked; however, on mine the heat slot was already partially blocked by the wood frame behind it. I did not notice this until I started this project and got down at eye level with the slot. I may at some point remove my slat support on that side and trim about 3/8" off the bottom, or just enlarge the heat slot to get the max heat flow, unlike the factory set up.
