Power converter alarm Tab 400
sdenhof
Member Posts: 43
My converter started an alarm sound....what does this mean? When I plugged it into the house it stopped. Assuming it means low power?
2018 Tab 400 towed by 2013 F150
Evanston Wyoming home
What is the state of charge of your battery when you are not plugged in? Several things can "chirp" when the battery is low.
Towed by 2014 Touareg TDi -
It could very well have been your Carbon Monoxide detector chirping. That happens when the battery is too low.
The battery was low and I checked where the chirping was coming from and was the converter for sure2018 Tab 400 towed by 2013 F150
Evanston Wyoming home -
What model converter do you have?
Most newer T@B320's have the WFCO WF-8735P. The operators manual for this model doesn't mention any audible alarms.
My 400 has model WFC 8955PEC. I also did not see any menaion of an audible alarm.
There are LED alarms on the converter.
Wonder if sdenhof's 400 has either or both inverter and solar charger that either one alarm was going off? Those devices are close to the converter on factory installed 400.Utah Driven
2019 T@B 400 (Ex 2018 400)
2015 MB GLK 250 Diesel
2018 GMC Canyon Denali Duramax CCSB
Thanks everyone. It stopped when I plugged it into shore power.2018 Tab 400 towed by 2013 F150
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
