Thanks to this forum I was encouraged to add more storage space for the external items used at the camp-site (water hoses, sewage hoses, leveling blocks, etc.). I found the perfect diamond plate tool box to add to the A-frame for the 320S so that all of those items would not have to be inside the storage space under the seating. Here is the photo:
The sloped Toolbox is a Brait BR302 Aluminum Tool Box for ATV Storage Truck Pickup RV, 30" L, Silver available at Amazon for $168.99 with the dimensions of 30 x 13 x 13 inches and a good locking device and key. It has a rubber seal round the top lid for keeping water out although I did find some water inside after a high wind rain day so I may put a few drain holes in the bottom. You can find the box here
https://www.amazon.com/gp/product/B00WRICSB2/ I mounted it to the A-frame using 4 3/8" bolts. The twin 2-gal water and 2-gal gasoline plastic jerry cans were purchased from Rotopax at this web-site and were not cheap
https://rotopax.com/ CincyKid
CincyKid
Cincinnati, OH
2019 Tab 400; 2019 TV Honda Ridgeline
CincyKid
Cincinnati, OH
What is that? What is entailed in doing this? Picture?
CincyKid
Cincinnati, OH
CincyKid
Cincinnati, OH
Sold 2023 Tab 400
Sold 2018 T@B 320S
CincyKid
Cincinnati, OH
CincyKid
Cincinnati, OH
CincyKid
Cincinnati, OH
I'm adding a Honda 2200i (47.5lbs) and an aluminum box for that (18lbs) and I'm a bit over. The actual calculation for the tongue wt. is to measure the distance from the end of the tongue to the middle of the trailer's axle (let's call that D1), then measure the distance from the end of the tongue to the center of each item your adding (let's call that D2). The weight added to the tongue by additional items is calculated as (D1 - D2)X10 = % of weight that is added to the tongue. I haven't measured the distances yet...
Just so folks are cautious about adding too much! Please correct me if I'm wrong.
Sacramento, CA
CincyKid
Cincinnati, OH
Your calc needs to be doubled to 60lbs. You have two cans for water and two for gas (4 gal. of water & 4 gal. of gas: (4x8)+(4x7)=60lbs). And what is the weight of the gear going in your added forward metal chest?
I don’t, however, know how much weight is transferred off you’re tongue by your stab/sway rig. The fact remains that I believe it’s the weight on the trailer’s tongue that is the guiding number, not the tow or hitch capacity. You say too little weight can cause swerve. What happens with too much weight?
NuCamp’s specs state a maximum tounge weight for everyone, not just for those with a more-than-sufficient TV. Could it be that the trailer’s frame’s tongue is the weak spot? Seems so, as excess tongue weight may void their warranty per my phone call. That’s my concern; the max tongue wt, not the min. That’s perhaps why T@B puts the max tongue wt in their specs...
So as I add stuff to the platform and in front of it, I’ll keep a very close eye on the tongue weight!
Best,
Bob
PS- your skills are admirable!
Sacramento, CA
CincyKid
Cincinnati, OH
Wavian USA JC0020RVS Red Authentic NATO Jerry Fuel Can and Spout System (20 Liter) https://www.amazon.com/dp/B011AJF0PE/ref=cm_sw_r_cp_api_i_OUJVCb2VC8EDP
Wavian USA 3216 5 Gallon Dring Water Can with Spout UV Stabilized BPA Free Textured Military Grade Heavy Duty Anti Bacterial Resin Made in Australia (Blue) https://www.amazon.com/dp/B01F7C0SFC/ref=cm_sw_r_cp_api_i_xVJVCbBM5SB6Q
NATO Style Steel Jerry Can Holder for 20 Liter (5 Gal.) Cans https://www.amazon.com/dp/B00VVFTDVK/ref=cm_sw_r_cp_api_i_4VJVCbERF77SJ
2018 Tab 400
2017 Jeep Cherokee Trailhawk
Husband, Nurse, Hufflepuff
