New 320S Owner - - early
modifications/additions before the Shakedown Trip.
1. Mounted a
Hopkins 09715
Hitch Level in
front of the Jack post.
2. Added a small width angle iron to rear edge of Tub Lid so plastic does not sag.
3. Installed
10W Solar Panel on Tub Lid with a 20W controller on bottom side for battery trickle charging.
Mainly for when T@B is at the RV Storage lot.
4. Mounted
Spare at Jack post. {no Outback
rear rack on my custom build unit}
Front spare mounting increased the tongue weight by ~ 45 pounds. {15-inch outback style wheel/tire}
5.
12V in-line switch pigtail to turn off
television blue light on order.
6. (forgot one) . . . before T@B arrived added a
12V Relay to TV 12VDC-to-Trailer circuit.
So T@B won't draw down my TV starting battery at long roadside stops.
Not a bad start . . . will be Shakedown
Trip ready soon.
Forum has been a wonderful place for
ideas and project how-to's.
Thanks to everyone.
White Tire Cover on Order.
Cable or Chain Lock to be Added
'18
320 S,
pitched axle, 3020HE; PNW based
2016 Jeep Cherokee & 2017 T@B Outback
No way as a retiree could I afford Solidworks at home.
Am using a free version of PTC Creo Element. It's interface is Solidworks like. Free version has some modelling limitations of course and limits each project to 60 part models. Not a big deal for what iff'ing small boat, home, car, RV garage projects.
Installation was easy. Just two WARNING points.
One. Be sure panel is forward on the Tub Lid so when the panel is flat and you open the Tub, the Tub lid will fully open to 90-degrees. If panel is too far back on the Tub lid it will hit the T@B front wall.
Two. Be careful not to drill your solar panel screw holes into the solar panel material.
I have not highway tested this installation. Seems to work well (stay flat for travel) around town including over speed bumps.
Installed
Urbana, MD
Standard hardware store U-bolt, believe they were 3.5 inch. Measured Spare Tire Mount hole space before going to store.
Red Padding is about 6-inch length (each U-bolt) of 3/8 I.D. Air Hose. Was a pain to twist onto the 3/8 bolt but doable. Used the Air Hose because of the red color, also considered marine fuel hose and clear tubing. Just picked 'the one I liked most' from the selection at my local hardware store.
Both items are from Amazon, other sources have similar products.
ACOPOWER HY010-12M Mono Solar Panel
Anself 20A 12V/24V Solar Charge Controller
Note: Controller is Not waterproof.
I mounted it on the bottom side of the tub lid
hoping to keep it dry.
Only wire that was included was a two conductor wire about 3-feet long connected to the solar panel. I purchased/made the controller to battery wire connections.
https://www.amazon.com/gp/product/B006FW3G2G/
Will have to add some of these to my "to do" list.
Now you've got me wondering if there is any reason not to permanently mount stabilizer pads & save all that backbending trying to position them.
Thanks for sharing.
The 50% Shade Garden Screen has also been a plus on two recent 100+F days helping the little A/C keep up with the sun.
The small shelf added to the Driver Wheel Cabinet is currently only used as a temporary storage location, a place to get items like shoes off the floor while in the T@B.
The aftermarket Solar Controller replacement should have been a simple 30-minute project. Due to human error it became a 2-day ordeal. If you're interested and missed the original thread on that one, try:
https://tab-rv.vanillacommunity.com/discussion/7467/bad-day-mod-update-broke-dc-system#latest
Am not sure there is any real 2x4 lumber in a model 320. The 'Studs' and support lumber seem to be 1x2, 1x3 soft (light) wood.
Would assume the 'Stud' in the bathroom wall NuCamp is referencing is the 1x? that can bee seen in the Shower Plumbing Access space. Picture below.
To mount the inside of Bathroom Grab Bar I removed the Tel-V to better inspect the wall construction and found there are 3/4 inch thick boards placed between the 'studs' to handle the Tele-V Mounting system & Tele-V weight.
Bathroom Grab Rail is screwed into those boards, which are behind the thin shower wall paneling. Believe that will provide the strength needed. Plus that Grab Bar is more for balance control while moving than dead weight lifting.
