Successfully eliminated “P” trap under sink with Hepvo valve
- Hash T@B Fun
@Dalehelman I really like this! Are you dewinterized yet and can play with it with water to see how it performs?2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
Parts list
https://www.amazon.com/dp/B00NLMPLDU?ref=yo_pop_ma_swf
Everbilt 1-1/2 in. Plastic Tee Slip Joint
See this on Homedepot.comOMSID#: 205153788
Store SKU#: 1000050260Qty: 1
Aisle: 08 Bay: 007
Everbilt 1-1/2 in. x 12 in. PVC Solvent-Weld-Joint Extension TubeOMSID#: 205154042
Store SKU#: 1000050266Qty: 1
Aisle: 08 Bay: 007
- Hash T@B Fun
3 -
You are awesome!!!John and Henrietta, Late 2016 T@B S Max in Western New York0
@Homebodyatheart
works as advertised. Garage never gets below 40*. IMHO it would ok to dewinterize now. Even if it were to drop below freezing at night it wouldn’t be long enough to do any damage.- Hash T@B Fun
Dale, that's excellent! I had no idea such a device existed!
About a year ago, I bought all the parts I'd need to reroute the drain and trap under the kitchen sink (ours drains toward the front of the cabinet).
Haven't got a round tewitt though, of course, and now I have to find a use for all those parts, cuz this is a much better solution!
Thanks Dale. Love it!Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
@Dalehelman I can’t make it this weekend but I’ll be there next week end. Beverages and food of your choice plus..
ok not really, but I’m gonna study these
pics in great and see if I can maybe try once more. Great work!
Mark - 2016 T@b Max S (Silver/Red), 2012 F-1500 -
Dale, there's a bit of a contradiction in your illustrations vs parts list...
The slip tee you used in your installation photos looks to be part of a 'slip tee / waste outlet' fitting. ie:
Wouldn't that be easier than the triple-slip tee?
Also, a question. The el between the sink outlet and the Hepvo is a slip fitting, isn't it? How do you seal the threaded sink outlet to the slip-fitting el?
edit: I now see, it's not a slip-joint. I found the video here.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
Note the Hepvo is a couple dollars cheaper directly from their website, here: http://hepvo.com/buy-now/
Dale, this might be your best mod, yet!!
Very true I can’t get anything by some of you. In my case I did use a T like you picture d. Instead of the slip fit T in the parts list. I all ready had one and it saved me a trip to HDIChanW said:Dale, there's a bit of a contradiction in your illustrations vs parts list...
placed it in the inverted position. By doing that it was necessary remove the baffle inside it with a small grinder. The standard slip T should be easier for the average person. Either way will get the job done.- Hash T@B Fun
If you do this mod. Be advised that it is necessary to reconnect the vent pipe at the top of the T fitting.
- Hash T@B Fun
I was sure that 39923 195944 bar code sticker was an important part of it, since it wasn't there in the earlier photo...
@Dalehelman Beautiful work (as usual!). Any concerns about odour from the grey water tank?
James & Jacquie Almonte, Ontario
2016 Jeep Cherokee & 2017 T@B Outback0 -
None take time to watch @ChanW video posted above.hymie said:@Dalehelman Beautiful work (as usual!). Any concerns about odour from the grey water tank?- Hash T@B Fun
According to a couple videos I’ve watched, the hepvo valve makes that vent pipe unnecessary. Would you comment?Dalehelman said:If you do this mod. Be advised that it is necessary to reconnect the vent pipe at the top of the T fitting.
https://m.youtube.com/watch?v=yfYwmKnWXXw
John and Henrietta, Late 2016 T@B S Max in Western New York0 -
@Photomom, I wondered the same thing, but got to thinking (uh oh). It's a possiblility that that vent pipe is the main 'stack' vent for the gray water.
IOW, the shower drain might also depend on that vent pipe. (I haven't looked in that wall behind the toilet in a while).
But, on second thought (uh oh!), combining a drain and a vent like that might be unacceptable...
Sigh... Like the discharge mod in that a shopping trip south may be in order. The challenge of living in the land of snow.... Good to know that direct purchase is an option because Amazon.ca is not.
If my plumbing schematic is to be believed, the gray tank (and by association the shower) do indeed vent up past the sink drain.ChanW said:@Photomom, I wondered the same thing, but got to thinking (uh oh). It's a possiblility that that vent pipe is the main 'stack' vent for the gray water.
So, while the Hepco valve itself may not require a vent, you should still reconnect as Dalehelman has.
Draining into a pipe that serves as vent for a fixture lower down is called "wet venting." Residential plumbing codes do prohibit it in certain situations, but I don't recall the specifics. I think it has to do with toilets on upper floors, so unless you've installed an extra can on the roof of your T@B, you should be good to go. ;-)
$216!?! What the heck is that about?
Must be the new tariffs! Jeesh!
I might just have to go into smuggling over the Peace Bridge. I'd clearly be able to make some good money! (JUST KIDDING, Customs Officer, sir!)Chan - near Buffalo NY
@ ScottG thanks for answering the question. You did it better than I could have. I tried without. The water entering the gray tank forced the air up through the shower drain. Correct that vent is needed for the shower.ScottG said:
Draining into a pipe that serves as vent for a fixture lower down is called "wet venting." Residential plumbing codes do prohibit it in certain situations, but I don't recall the specifics. I think it has to do with toilets on upper floors, so unless you've installed an extra can on the roof of your T@B, you should be good to go. ;-)- Hash T@B Fun
Thanks, @Dalehelman. I always appreciate a good "try it and see what happens" to back up the theory. Now we know!
The Dutchman T@Bs have a strainer/sink adapter that includes a check valve style waterless trap. In the picture it is the round bottom white unit on the bottom of the sink. The entire drain plumbing is the corrugated grey hose leading to a 3/4 inch threaded hose connection beneath the trailer.
@Sandiegogal Our next mod......this will eliminate the weird smell in the trailer. HepvO® valve.... who knew this even existed? The HepvO® valve means enhanced plumbing design and system efficiency, without compromising performance or risking the escape of foul air into the living space from the drain or sewer.2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.0
I assume you have know holding tank. If that is true then no “P” is neededrfuss928 said:The Dutchman T@Bs have a strainer/sink adapter that includes a check valve style waterless trap. In the picture it is the round bottom white unit on the bottom of the sink. The entire drain plumbing is the corrugated grey hose leading to a 3/4 inch threaded hose connection beneath the trailer.
- Hash T@B Fun
Very cool, but I have to admit I'm not sure what the reason was - is this a plumbing improvement, or done to buy more storage space under the sink?0
More storage easier access.
- Hash T@B Fun
@Dalehelman in the third picture, on the floor of the cabinet, are those shavings from having to cut something?
Yes it is necessary to cut 8” from the drain pipe. It is important to make the top cut 3/4” from the top 45* elbow.jkjenn said:@Dalehelman in the third picture, on the floor of the cabinet, are those shavings from having to cut something?
- Hash T@B Fun
Thanks!
