CS-S bathroom sink removal and new sink in storage area
Pieshobbithouse
Member Posts: 17
2018 CS-S
2018 CS-S3 -
Nice work, @Pieshobbithouse!
I think I see how you handled the supply lines, but how did you deal with the drain?
2018 CS-S0 -
I used the 1 in flex line from Home Depot you can see under the sink. It is run around and under the shower pan. When you look under the seat into the area open under the shower pan you can see all the way to the front wall. open the bathroom access door and grab it and snake it through a 1 inch hole drilled from the cabinet side. I can send more pics if anyone is going to do this. Also the caulking comes off with a rub of low Oder mineral spirits and a plastic razor blade from an auto parts store or west marine.
2018 CS-S1 -
looks great and gives a few extra inches of movement in an already TINY shoiletFormer 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada0 -
I would like to see someone install a drop down sink above the clamshell toilet. You would have more room and a sink.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
