CS-S bathroom sink removal and new sink in storage area
2018 CS-S
  • Pieshobbithouse
    Pieshobbithouse Member Posts: 17
    2018 CS-S
    ScottG Administrator Posts: 5,691
    Nice work, @Pieshobbithouse!
    I think I see how you handled the supply lines, but how did you deal with the drain?
  • Pieshobbithouse
    2018 CS-S
  • Pieshobbithouse
    I used the 1 in flex line from Home Depot you can see under the sink. It is run around and under the shower pan. When you look under the seat into the area open under the shower pan you can see all the way to the front wall. open the bathroom access door and grab it and  snake it through a 1 inch hole drilled  from the cabinet side. I can send more pics if anyone is going to do this. Also the caulking comes off with a rub of low Oder mineral spirits and a plastic razor blade from an auto parts store or west marine.
    2018 CS-S
  • ontheroad
    ontheroad Member Posts: 489
    looks great and gives a few extra inches of movement in an already TINY shoilet
    Former 2017 T@G Max XL
    2021 T@B Boondock CS-S
    2018 Nissan Pathfinder
    Ontario, Canada
    I would like to see someone install a drop down sink above the clamshell toilet. You would have more room and a sink.
