Motorized or Hand Crank Hitch Jack to easily move T@B around?
tenkarajunkie
Member Posts: 18
saw a cool Trailer Valet online that allows easy single person moving on trainers in tight spaces? I asked on Facebook group but the one person that tried it, said Trailer Valet would not mount on T@Bs. Anyone successfully install and use something like this? Thanks. TJ
Nope but if you're in campgrounds with paved pads, it's very easy to move @ T@b with the standard jack wheel. I've even done it on good packed dirt pads. Sandy pads are a different story.
It's for my home situation. Garage up on grade and really tight. :-)
If you look on Amazon, it doesn't get great reviews.
Carol Kelly has a motorized one. She has a video posted. I thought it was on the FB site, but maybe it's only on her blog.Crystal & Daisy, a yellow 2007 T@B Q previously towed by a 2008 Jeep Liberty, and currently towed by a 2016 RAM 1500.
TABaker, yup I saw hers. She was kind enough to tell me about it. That style is a bit too steep for me at $900 or so. Hoping one of the hand crank style for $300 or less has been proven to work on T@Bs. So far I have only heard of one person trying the Trailer Valet and it did not work. I see other hand crank brands and hoping one may work. Otherwise I will just deal with what we have. ;-)
Have you considered a trailer dolly?
The mechanical dolly from powermovers.com looks interesting. It cost a little more than the Trailer Valet, but you wouldn't be adding 45 lbs. to the tongue weight. And, you don't have to bend over!
2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
I meant powerdolly.com2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
jkjenn, I see those dollies but they all seem to be rated for 600 pounds. Not so sure they will help much on a 1600 pound TAB. I have a incline and weather speed bump to get over. If all I had to do was move it a few times a year, no biggie, but it takes up my main stall in the shop and will need to be moved all the time weekly. That will get old so looking for a effective solution that does not break the bank. But thanks for the suggestion. I did see those too. ;-)
I think the 600 lb rating is for tongue weight, not trailer weight.tenkarajunkie said:jkjenn, I see those dollies but they all seem to be rated for 600 pounds. Not so sure they will help much on a 1600 pound TAB. I have a incline and weather speed bump to get over. If all I had to do was move it a few times a year, no biggie, but it takes up my main stall in the shop and will need to be moved all the time weekly. That will get old so looking for a effective solution that does not break the bank. But thanks for the suggestion. I did see those too. ;-)Ray and Vida Barrick
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
