Outback Tire Suggested Replacements
Any suggestions on a replacement tire with the same aggressive tread pattern as the original Westlakes? I've had good luck with the original tires but I would like to upgrade to a non Chinese made tire. Most ST type tires don't have the tead pattern I want. There are tons of light truck tires that fit (235-75r-15) but I'm not sure the sidewalls are strong enough. I'm going to the tire shop this week to ask but I was hoping someone had a solution from the site who had already upgraded.
    MuttonChops Posts: 2,050
    . . . There are tons of light truck tires that fit (235-75r-15) but I'm not sure the sidewalls are strong enough.  . . .
    My Feb-2018 built T@B has Milestar (China) 235 / 75R15 XL instead of 'ST' construction tires direct from NuCamp.
    I researched this tire type an found:
    . . . The XL designation has less to do with actual load carrying capacity and is more about the tires internal construction. XL designated tires have additional material added to the shoulder of the tire for extra strength. These reinforced shoulders (usually accomplished with polyamide belting found where the sidewall and tread meet) are designed to minimize any tire deflection and reduce the chance of having a road impact injury. Tires that are engineered with reinforced sidewalls are considered to be XL or RF tires (with RF tires having even more reinforcements than XL tires) and typically fall into the performance tire category. . . .
    Standard 'ST' tires also have stronger/reinforced side walls.
    Speed and Load Rating of tire is also important.
    The Milestar 235 / 75R15 XL are
      Load Index  109   { 2271 pounds at 50PSI }
      Speed Index T      { 118 MPH }
    Suggest you make sure your replacement tire meets or exceeds the Speed/Load rating of your presently installed tires.
  • db_cooper
    db_cooper Posts: 749
    Our General AT Grabbers have been great, will buy again if they still make them when we need them.
  • tabiphile
    tabiphile Posts: 472
    Make sure that you are buying the properly load rated tires...and then keep them properly inflated.
    http://www.besttraveltrailers.org/best-travel-trailer-tires/
  • jkjenn
    jkjenn Posts: 6,424
    I will second this. They are a reasonably price, quality A/T tire.
  • Fatman1966
    Fatman1966 Posts: 149
    I I think I will look into the General AT Grabbers. Thanks
  • Luckyj
    Luckyj Posts: 286
    I do not know about the T@G, since We own a T@G outback, but I did compare my T@G tire with my jeep wrangler tire, and my load range D original jeep Good Year wrangler tire had a bit higher load range than the TAG and of course, a higher speed rating.
    I would see why trailer tire have a trailer only regulation, but do not understand why a vehicule tire would have a non trailer possibility.
    and yep, side wall are the same construction.  And load is at a slightly lower pressure on my jeep tire.
    so, I would say, just shop around and ask questions.
    TV 2005 jeep TJ unlimited
    Alaskan Malamuthe on board!
  • Speaking of Outback tires... We have a 320S with the Outback axle and tires. I was working on the trailer and went to remove the tire and was surprised that if I didn’t crank it up real high I could not get the tire to clear the plastic wheel well molding. The tire is bigger around than the wheel well lip. Has anyone else noticed this?
