Battery hookup
I had a neighbor remove my battery for the winter.  I had asked him to take a picture of the setup before removing the battery, but he forgot.  Now I'm confused as I see four cables to attach to the battery.  Do I connect BOTH of the white cables to the negative post and the red AND blue cables to the positive post?
2017 white/black trim T@B Outback; 2017 white Subaru Outback; Seattle
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,010
    If you have the solar port on the propane tub, you should have a red and white cable extending from that port to the inside of the tub.  The red is positive and the white is negative.  The blue cable probably holds a plastic fuse box and the cable may be spliced into a red cable - that goes to the positive terminal of the battery.  The other white cable goes on the negative terminal of the battery.  Here is a picture of mine.  Ignore the thin, red cable as it supplies the charge to an optional battery monitor.  Make sure you put the negative cable on last.
  • SeadusterSeaduster Member Posts: 147
    Forgot to include a picture of the cables...
    @SAM Thank you.
