Table mechanism
julz
julz Member Posts: 32
Can anyone tell me how the table in the T@B Sofitel works?  I can't get mine to lower and I know Im going to pinch the heck out of my fingers if I do this wrong...
Im sure its simple but I cant figure it out and I can't fine any info on it.
  • jkjenn
    jkjenn Member Posts: 6,425
    Should be the same mechanism: https://youtu.be/5-RJQRn_Hsc?t=9m2s
  • Rad
    Rad Member Posts: 516
    edited March 2015
    There is a release lever half way down the leg near the angle section of the table top. After you release it you push the table top from the long end opposite the lever release.  The leg then hinges like a knee joint and the table goes down.
    To put it up, don't lift the top, once again push the top towards the hinged release side and lift at the same time.  Cleaver design, just not very intuitive.
  • julz
    Thank you!  I got and I didn't even pinch my hand.
