Table mechanism
julz
Member Posts: 32
Can anyone tell me how the table in the T@B Sofitel works? I can't get mine to lower and I know Im going to pinch the heck out of my fingers if I do this wrong...
Im sure its simple but I cant figure it out and I can't fine any info on it.
Should be the same mechanism:
https://youtu.be/5-RJQRn_Hsc?t=9m2s 2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
There is a release lever half way down the leg near the angle section of the table top. After you release it you push the table top from the long end opposite the lever release. The leg then hinges like a knee joint and the table goes down.
To put it up, don't lift the top, once again push the top towards the hinged release side and lift at the same time. Cleaver design, just not very intuitive.
Thank you! I got and I didn't even pinch my hand.
- 916 Introductions
- 72 Teardrop Groups & Links
