Is the solar panel controller function in the 400 automatic or does it need some manual intervention. I have a manual for it that came with the trailer. It lists some settings that can be changed - but is that necessary? Or, does it just work automatically hands off?
2018 T@B 400 - 2017 Chevy Colorado
0 ·
In short, you probably don't need to change anything. However, I believe the T@B 400 has a a larger AGM battery, so the optimal settings may be different than for basic wet cells. If that's the case, whether those settings were changed at the factory is anybody's guess.
Not really an answer, I know--just something to be aware of. Hopefully someone with a 400 w/ solar can better advise you.
