Hello. I’m looking for recommendations for two items. I don’t know exactly what they are called so I will describe. The first is a gauge to show how much fuel is in the propane tank. The second is an adapter (splitter?) that will allow me to hook up a grill or Coleman stove to the propane so I don’t have to bring multiple propane tanks. Ideally, the adapter and the fuel gauge can both fit on the tank at the same time so I don’t have to fiddle with anything once they’re attached. Any ideas? Thanks!
2018 T@b 320S Boondock, towed by 2012 Toyota Highlander Hybrid
0 ·
Camco 59133 Brass 90 Tee with 3 ports
It works great and is one of the best purchases I've made. You also will need a hose to hook your adapter to your device:
Camco 59043 12' Propane Extension Hose
As for screw-on guages, the conventional wisdom is that are mostly useless. They are pressure-based, and as a result they don't really register until your tank is just about to run out. A much better option is the Worthington tank with an integrated float guage. U-Haul also sells them under their own label and typically have the best prices. I picked up mine at my local store. Once my other two tanks "expire' they will be replaced with these!
If you are interested do a search here and you should find several threads on the topic.
