stabilizer jacks
Bristang5
Member Posts: 2
Just bought a 2005 tab 320 and love it but the rear jacks are bent....I cannot seem to find OEM parts like this....any ideasj as to where I can find these jacks? I might buy some scissor jacks and install them but would prefer to get correct ones....thanks...
I’m sure Elsie @ Nucamp can source them.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
Just BAL jacks can be bought on line or CW2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az -
I ordered them from nuCamp. $40 each last year. I had my trailer shop install them.
Katt and Miss Cannoli the Zen Dog
2008 DM T@DA — Towed by 2014 Dodge Durango — Full time since 6/29/17
"Travels With The Tiny" -
@Bristang5, if you bought a 2005 t@b, it is a Dutchman (manufacturer). There is no such animal as a 2005 t@b 320. Please check what you actually have purchased. However I can add that Elsie @ Nucamp can probabaly help you out either way, but you have to be sure what manufacturer built the t@b you have. Elsie's contact info can be found in the categories at the far left of your screen, under contacts. Good luck, welcome to the forum, the t@b family and congratulations on your trailer! Happy t@bbing!
Draco dormiens numquam titilandus. -
Technically, my 2015 T@b would not be a 320 by this standard. I believe the designation 320 is mostly used as an adjective to describe the non 400 models.dragonsdofly said:@Bristang5, if you bought a 2005 t@b, it is a Dutchman (manufacturer). There is no such animal as a 2005 t@b 320. Please check what you actually have purchased. However I can add that Elsie @ Nucamp can probabaly help you out either way, but you have to be sure what manufacturer built the t@b you have. Elsie's contact info can be found in the categories at the far left of your screen, under contacts. Good luck, welcome to the forum, the t@b family and congratulations on your trailer! Happy t@bbing!
@Bristang5 @Dalehelman helped me install scissor jacks I purchased in place of my rear stabilizers. You have options, although you would want to check the bracket/screw hole patterns so you match them into the framing. Good luck!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
