The last camping trip of the 2017 season in Delaware our Alde stopped working and gave a "connection error" on the control panel. Our dealer and the techs at nucamp were unable to suggest anything over the phone that I hadn't already tried. We made arrangements to have a new circuit board installed at our dealer when we returned to New York. After the new install, the Alde worked and it was the end of the season. We winterized and put it up for the winter.
Today, I drained out all the RV antifreeze from the fresh water system, flushed everything out and fired up the Alde. All afternoon I had hot water and heat on electrical power. When I decided to call it a day around 4:00PM I went to lower the thermostat and got a "connection error " message again. So, the new circuit board worked for about 3 or 4 hours. I tried to reset the Alde per the manual by disconnecting the 12v power and reconnecting with no success. I checked continuity on both fuses and they were fine. So here I am. No hot water, no heat and a six week trip ahead of us to California.
Anyone out there have a similar problem?
Earl & Sue | Central NY |
2017 T@B 320S | TV: Chevy Silverado
0 ·
Just to make this problem more interesting, here is the new twist. This problem only happens (so-far) in the heat of the day. At night the error message goes away and the Alde works normally with heat for the camper and hot water for the sink and shower. Once the heat of mid day comes around, the system goes back into default with the "connection error" message. This has happened for (4) days now.
I meant control panel/display.
Let me know via PM if you want it.
By the way, during this process I did find out from Spencer at Alde that the Alde systems are warrantied for two years not one.
I had a problem this weekend where the thermostat/controller just started wigging out. It automatically rebooted twice, and after I reset it to factory defaults, it wouldn't restart.
We went without it for the night. In the morning it still wouldn't start with the power button. It wouldn't start by holding both buttons down or one or the other, etc....
So as a last ditch effort I did what every man does, I opened the hood and stared at the engine. I opened the compartment and looked around at all the Alde hoses and at the big pretty box. I took off the fuse plate and looked at it. Then...I saw a wire that looked like it might go to a thermostat, so I unplugged it and plugged it back in. BINGO, the thermostat restarted. It worked fine for the rest of the weekend.
I'm not sure if it is fixed for good or if I have a workaround for a lifelong problem. Unfortunately it is so hard to get dealers to replace (under warranty) things that only fail intermittently.
Weird stuff.
P.S. I have also vindicated myself about the wisdom of opening the hood and staring at the engine.
