T@B 400 - Where Is The Air Conditioner Filter?
newbie
Member Posts: 30
Manual says to keep the filter clean, but where is it and how do you access it?
2018 T@B 400 - 2017 Chevy Colorado
The filter sits just behind the front grill. Slide it out from the right side.
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
There doesn't appear to be a front grill on the 400. I only have slats in the wood trim panels that are maybe for air return, but no way to access what's behind the panels.2018 T@B 400 - 2017 Chevy Colorado0
Oh, sorry. Did not see that it was a 400.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
The filter can be accessed by removing the 2 screws holding the drivers side dinet bench seat in place. You will want to have your table in the lower position, or remove it, before sliding the bench seat out, since it is very large and a bit awkward. The filter is right behind the wood slotted vents.Happy Trails,
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
3 -
Thanks for the info. What a procedure! A better design would be nice. Wow, you'd think that the manual would give instructions on how to access the filter where it says to clean the filter.2018 T@B 400 - 2017 Chevy Colorado2
I just took the bench apart and found there wasn't any filter and nothing to hold a filter in place if there was.0
Actually there is a better way but it requires a mod. Austin installed this flip access for us allowing us to just lift the seat cushion, open this access and slid the filter out for cleaning. It’s a hinged access door just above the filter assembly. It could be an easy DIY project, easily done by a dealer, or by nüCamp. Eliminates the need to remove cushions, table, screws, and compartment cover and makes cleaning the filter a cinch. Hope this helps!
Steve and Karen Cullowhee, North Carolina 2008 Ford F150 --2018 T@B 4004 -
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
