We have been trying to find a suitable way to put a cover on the spare tire attached to the Yakima Rack on the back of our 2015 Outback. On close examination the tire is clamped hard on the rack. I can loosen the tire clamp and slide the cover on but then have no way to retighten the clamp because the cover is over it. Is there someway to put a spacer between the rack and the tire that anyone knows of. I have a request for help in with Yakima and Ed at Pleasant valley so will let you all know what I find out but hoping one of you might have solved this problem.
                0 ·
Hopefully we get our Outback in about a week. I was planning on a tire cover too. Let me know what you guys do. Not many of them out there yet.
Since the Outback has better ground clearance, I was wondering if the spare could be mounted under the trailer like the standard T@B. What do you think? Have you looked under yours to see if there are fittings there for a tire mount? I was hoping the factory at least left the holes for a mount.
What do you think of the Outback? We haven't even seen one in person yet.
I know, I'm asking too many questions.
SusanB
Do you think a continental kit would work?
These are pricey. Wonder if they have enough grip on the inside of the tire?
http://www.rvandvansurplus.com/tirecovers.asp?Vehicletype=RV
"I am curious as to how this rack is mounted as most racks are mounted to the roof, hitch or spare tire. If the rack is mounted to the back spare tire, there would be no way to place a tire cover on without making a hole for the mounting hardware from the rack to mount to the tire."
So it sounds like you would have to have a Donut shaped cover.
SusanB,
There's another question I have to ask. The Outback has that aluminum storage platform on the front. Does that platform interfere much with backing-up the trailer. I'm worried about the platform hitting the TV bumper in a jackknife situation. Have you guys checked that?
Thanks
